Greetings, I have a renault megane 2-1.5dci 2006 with a no-start problem for over 4 months. Changed many parts but still not right. This is what I want to do and I need advice as to whether this will work or not. I am only receiving 2.8 volts power across all 4 injectors with ignition on. Should be 12v. Cannot trace continuity from power injector wire to ecu connector wire. So I want to connect the 4 power wires from my injector connector to the power wire going into pressure regulator on tthe fuel pump. That will send 12v to the injectors when car is on. I will leave the injector siignal ecu wire as is. This will give the original injector power wires connected to nothing or open circuit. Hope thats not a problem. Please advise.
Injector wiring
Users browsing this forum: Google [Bot] and 83 guests
