Any idea which of the dozens of readers/scanners will be OK for a Megane Scenic '06 ? They all seem to fit everything from 1996 but some apparently do not.
Thank you for any help.
OBD2 scanners/readers
- Currently Drives:: Megane Scenic '06
- Currently Drives:: renault megan dynamique 2006
Re: OBD2 scanners/readers
Renault can clip covers everything others don't... So I suggest buy that for about £100 worth it.
- megane1600
- Currently Drives:: megane 2
the genuine can clip cost a lot ,there are two types of clone out there the green(board) and the gold(board)Buy the the gold version its the best quality and can do everything like the genuine one.
https://www.aliexpress.com/item/For-Ren ... 4c4dosA6Qt
- Currently Drives:: Mondeo TDCI mk3 2002
Pug 307HDI90 1.6 (family car)
I am on my third can-clip.It is impossible to run an old Renault without. They fail after a year when the warranty is up or so it seems. I have tried both types and they both failed. The last one I bought is working OK but I note from ebay that the seller has been withdrawn so I won't even have a year's warranty! Curses. I obtained Renault-com (Superscan) and installed that (bluetooth connection). Too early to reach a conclusion at the mo but some trouble getting and keeping connections to the DCU. It is not so comprehensive as can-clip. It showed no faults at all whereas can clip showed several that were stored. The stored faults did not affect the running but gave an indication of what had been faulty. I must say that I have not found can clip easy to use with the mk 3 as it uses a different system (bornier 3). Must try the superscan on it. Luckily the mk3 is far more reliable than the mk2 !
A "genuine" version of can clip would cost almost two grand!
In the early days I tried other code readers including elm327 but they were useless. Probably because my 2003 car is not OBD compliant. As Drewster 1978 said, can clip covers everything!
Users browsing this forum: Google [Bot] and 61 guests
