I have a Megane 1.6 dinamique auto.
Car has developed a fault.
From cold, car drives ok, until the engine gets warm.
Once I've stopped and try and move off again, the engine instantly cuts out.
However if I put the car in reverse, it doesn't cut out at all.
I've had the driveshaft sensor replaced and still have the same problem.
Any ideas anyone?
Rich
Engine cutting out
- Currently Drives:: Renault Megane 2 1.9dci
Re: Engine cutting out
Hi Rich,
Did you come right with this?
I'm experiencing the same issue with my Megane 2 1.9dci I am clueless as to what could cause it.
So i eventually came right. Turns out all i needed to do was remove and clean the TDC sensor (crank sensor) . Put it back and voila, no more engine cutting out.
Users browsing this forum: No registered users and 70 guests
