hi i have a renault megane cabrio 1.6
it was running fine went to beach and it wouldnt start it didnt cut out i turned engine off .
anyway called rac no faults found towed me to a safe place next day i went to car started first timed smelled like pettrol for a thew seconds and then got home hour later wouldnt start and this cycle remained for a week then it just didnt start .
it tryed to start cranking etc just wouldnt fire up i purchased diagnostic kit no fault codes found checked fuses no problems in glove box cant seem to get to ones in bonet checked one big 70 amp fuse as i could reach no issue reconected battery constant tone from bonet and nothing works lights dash doors etc any help massively appriciated 2008 plate
thanks mike
Megan cabrio 08 plate won't start
Re: Megan cabrio 08 plate won't start
Have you checked the fused on the battery positive lead, the ones in the red box.
Other than that I would be checking all of the fuses including the ones under the bonnet.
Cheers.
Cheers.
going to check in a minute ty for reply
Users browsing this forum: Google [Bot] and 76 guests
