Hi
I have a 2004 reg megane II this morning I noticed the gear stick having alot of movement when I break and accelerate. The gears are smooth, there's no clunking or banging or strange noises. I have no issues getting in any of the gears and I have no vibration. I wondered if the gear box mount might be very worn or broke ? Or if any one knew what it could be, you can see the gear stick moving on its own which is worrying me. I don't want to take it a garage just yet as I do fix most things myself with my trusty Haynes and I know they will try telling me I need a new gear box which I'm 99% sure is fine ?
Any help would be greatly appreciated.
Jenny
Gear box mount ?
Re: Gear box mount ?
The gear stick movement you mention could be caused by worn or broken gearbox / engine mounts, if you know it's not right you should have it looked at.
Cheers.
Cheers.
Hi
Yeah it's been parked up yesterday and I'm going to Jack her up and look today I can look at it myself. I just wanted to know if I was right that it's a mount and not the gear box.
I think it's the lower one that's attached to the subframe, I'll start there first. Thanks for your help
- Currently Drives:: Renault Megane 2 1.6 16v Maxim
It's not your gearbox given your symptoms. The rear torque mount is most likely your culprit. The bushes are prone to splitting. I've replaced my right side engine mount as there was excessive movement and also the lower mount which had completely failed. Symptoms of failure of these mounts are engine jolting when letting off the gas, gearstick moving forwards and backwards under acceleration / deceleration and at worst engine banging when driving over rough ground or speed bumps. When replaced you'll actually find that you feel slight engine vibration as the new mounts settle in. This is normal as the bushes are solid. Best to replace all 3 however I found no fault with my gearbox mount when replacing the clutch so just changed the 2 that were worn / split.
Users browsing this forum: No registered users and 89 guests
