Air con
- Currently Drives:: renault megan dynamique 2006
Air con
I bought a diagnostic tool to see what the problem is with the air con and I got a code df1070 cool loop which doesn't want to want to clear.. Also says refridgerent pressure is 0.80 bar to low and power absorbed by the ac compressor 300w.air con authorisation YES.the compressor doesn't kick in when pressing button so will it just need regassing and see what happensi changed air con pressure sensor last week..
So if I get it regassed and see if fault code goes and hopefully the compressor kicks in I do know the compresssor works I ran 12v to it.
Re: Air con
Hi there, could you please tell me where the ac compressor is located on the Megane 2 on 55 plate many thanks
Re: Air con
Hard to see from top of engine. If you take bumper off you can see it. Or take under tray off and it's on drivers side of the engine
Re: Air con
Rowdy55 wrote:Hi there, could you please tell me where the ac compressor is located on the Megane 2 on 55 plate many thanks
If you send me email address I've a picture of it.. With bumper off
Re: Air con
Hi thanks for your reply. Email address is blitz1948@googlemail.com
Re: Air con
Hi sent you a email
Re: Air con
Many thanks for your email containing picture of the compressor. The Renault designers must have had a really bad day to think of putting t it there. Cheers.
Got email with video but can't see it? I've just got this Huawei phone so still exploring what's what on it.
Next question is location of pressure sensor and temperature sensor? Thanks for your help, greatly appreciated.
Re: Air con
Yeah wouldn't let me send video over a certain limit only realised after I sent... Pressure sensor I will see if I've got a pic of that.
Re: Air con
Picture sent of pressure sensor for air con.
Re: Air con
Temperature sensor on wing mirror underneath..
Re: Air con
Got pic of pressure SENSOR, many thanks. Often wondered what the little blob under the wing mirror was!
Thanks again.
When I press ac button light comes on but that's all, can't here ac clutch come in. Spoes I'd better start testing things. The thoughts of going to Halfords or an aircon con man as I call em doesn't bare thinking about, the cheepest quote I've had for a basic "inspection" was £60 ### thanks for your help. Cheers.
Thanks again.
Re: Air con
I fixed my air con finally today I replaced sensor and new connector to compressor I while back so last week bought a adapter for high port and regassed with a DIY kit a it's working at last so just gonna keep a eye on the pressure with renault can clip.. Hopefully won't have any leaks..
Re: Air con
Hi did you regass it at the port above the engine. The one with the black cap? What adapter would I need.
Went to Halfords again tother day said he could not test it because he needed to get to the one under the car but they haven't got a lift/ramp.????? So they didn't bother.
It's like being in a circular firing squad at the minute when you go to Halfords!!!!
Re: Air con
Yeah remove black cap, search on ebay for renault gig side low port adapter I paid £11,then I got a top up bottle off amazon for £16 and also a pressure gage. I'm lucky I've got a can clip diagnostic so it show how much pressure in the system before I did it it shows 0.60 bar now its about 6.0bar.but the gage you buy will tell you. I went to halfors before I bought a adapter they are useless.
Re: Air con
Also there isn't a port under the car just the one on top of engine
