Won't start
Regisgrate
Currently Drives:: Megane 1.5dci
Won't start
Postby Regisgrate » Tue Jan 15, 2019 10:14 pm
I recently changed the battery on my megane ll and now it won't start. Does changing the battery affect the immobiliser in any way
VroomVroomClonk
Re: Won't start
Postby VroomVroomClonk » Wed Jan 16, 2019 12:50 pm
It shouldn't do.
I've removed and refitted my battery several times and the only additional thing I've had to do is re-input the security code on the stereo.
JonJames83
Currently Drives:: Megane II 2005 2.0 Petrol Hatch 6speed manual
Re: Won't start
Postby JonJames83 » Thu Jan 17, 2019 3:13 am
If its a new battery it should start, a second hand one might not have enough power to crank it , and remember you need to put your foot on the brake or clutch and hold start button. LOL
Regisgrate
Re: Won't start
Postby Regisgrate » Thu Jan 17, 2019 9:39 am
Foot on brake, push button.... Nothing happens and it's a brand new battery. There's a woman posted with same problem
joe12
Currently Drives:: Megane estate 1.5dci 86
Re: Won't start
Postby joe12 » Thu Jan 17, 2019 2:38 pm
Give this a try...
Put card in slot (DO NOT press the brake or clutch) >>
Press and hold the start button until the ignition comes on, wait 30 seconds >>
Turn ignition off by pressing start button twice >>
Lock and unlock the car >>
Card in slot try to start car normally.
Cheers.
Regisgrate
Re: Won't start
Postby Regisgrate » Thu Jan 17, 2019 8:35 pm
Thanks will give that a try
joe12
Re: Won't start
Postby joe12 » Fri Jan 18, 2019 10:01 am
Well ?
Regisgrate
Re: Won't start
Postby Regisgrate » Sun Jan 27, 2019 12:39 pm
Still won't start. Could it be a faulty button or starter motor
joe12
Re: Won't start
Postby joe12 » Sun Jan 27, 2019 6:55 pm
Check that you are getting 12volts on the trigger wire at the starter motor solenoid when the start button is pressed.
Users browsing this forum: No registered users and 46 guests
