Won't start
- Currently Drives:: Megane 1.5dci
Won't start
I recently changed the battery on my megane ll and now it won't start. Does changing the battery affect the immobiliser in any way
Re: Won't start
It shouldn't do.
I've removed and refitted my battery several times and the only additional thing I've had to do is re-input the security code on the stereo.
- Currently Drives:: Megane II 2005 2.0 Petrol Hatch 6speed manual
Re: Won't start
If its a new battery it should start, a second hand one might not have enough power to crank it , and remember you need to put your foot on the brake or clutch and hold start button. LOL
Re: Won't start
Foot on brake, push button.... Nothing happens and it's a brand new battery. There's a woman posted with same problem
Re: Won't start
Give this a try...
Put card in slot (DO NOT press the brake or clutch) >>
Press and hold the start button until the ignition comes on, wait 30 seconds >>
Turn ignition off by pressing start button twice >>
Lock and unlock the car >>
Card in slot try to start car normally.
Cheers.
Cheers.
Re: Won't start
Thanks will give that a try
Re: Won't start
Well ?
Re: Won't start
Still won't start. Could it be a faulty button or starter motor
Re: Won't start
Check that you are getting 12volts on the trigger wire at the starter motor solenoid when the start button is pressed.
Users browsing this forum: Google [Bot] and 73 guests
