Side light flashing
- Currently Drives:: renault megan dynamique 2006
Side light flashing
Hello when I put my left indicator on the back side light flashes slightly when there on, is it a bad earth if so anyone know the location of the earth to the body..
Re: Side light flashing
Check the plug connection to the light cluster for a bad / dirty connection, clean the connections up and give them a smear of grease when reconnecting.
This video may help --- https://www.youtube.com/watch?v=sQkMBeLduMU
Cheers.
Cheers.
Cheers seen that video I'm subscribed to him.. Took out the bulb nothing looks corroded wires to the connectors seem fine can I spray the connector with electrical spray cleaner..
Yes electrical cleaner will be fine on the connectors.
If you haven't done so I would check the connectors on both back lights.
I would also remove every bulb in each cluster and make sure the earth point for each is nice and clean.
If after checking all of that the fault is still there I would figure out which wire was the earth and connect a temporary wire from there to the clean metal on the body of the car to see if that cured the fault.
Cheers.
Cheers.
Many thanks I will try that.
Users browsing this forum: No registered users and 49 guests
