Is there any way to bypass the key card on a megane cc
I'm in Spain and every where is closed till the 8th of Jan due to 3 Kings
Getting messages no card detected,tried the knife trick but that's not working
HELP
Help needed
- Currently Drives:: Renault Megan cc 1.6 black with black leather
Help needed
Re: Help needed
That's a predicament you're in
I don't think there is a way to bypass the key card.
If the card isn't been detected it's a fault on the round black coil inside the key card, probably one or more of the three solder joints on it have cracked.
Give this a try.... https://www.youtube.com/watch?v=-hs1prW6Ct4
If that doesn't work I would take my time and cut the card open, there are videos on you tube showing how to do this, study a few of them so you know what you are doing, make sure just to cut in a little bit don't put the blade in deep as you don't want to hit the circuit board.
With the card opened up you stand a much better chance of finding someone who could solder the coil contacts for you if you can't do it yourself.
Alternatively you could try and wedge the coil to make a contact and tape the card back together as a temporary measure.
You can buy new replacement card covers on ebay so it's not the end of the world if you mess yours up a little when cutting it open.
Hope you get it sorted.
Cheers.
Cheers.
Re: Help needed
Ok so I've opened up key card and all looks fine but just to be on safe side I redid the solder on the 3 joints still not working opens car fine and locks it but that's it
Re: Help needed
In my experience of the cards soldering the 3 joints always fixes them!
If the card was working as in starting the car then all of a sudden it's not working, (not being seen by the card reader), it is always a broken joint on the coil contacts, and I've fixed a few of these cards.
I suppose the coil could be defective but that is very rare.
Watch this video below from 3:16 and you will see that the guy is repairing the very thin wire from the coil, maybe this is your problem.
https://www.youtube.com/watch?v=Bv4JAA8rm4o
Cheers.
Cheers.
Re: Help needed
This video shows the coil solder repair with a little more close up detail.
https://www.youtube.com/watch?v=XX9In1g_JvY
Cheers.
Cheers.
Re: Help needed
Well got the car sorted was the transponder in the key
So had to have some one come out and reprogram a new key an hours work and me out of pocket of 195€
But I've got me car back
Happy but broke
Happy but broke
Re: Help needed
Good to hear that you're sorted.
Cheers.
Cheers.
Users browsing this forum: No registered users and 81 guests
