Hi my daughter has a 08 megane 1.9 dci I think its the 130hp version , just recently its flashed up the dreaded check injection and spanner symbol also gone into limp mode, I removed the brake switch , cleaned it and think buggered it up so new one on order, I borrowed a mates old code reader and the two codes active were 0530 and 0380 can anyone please point me to a list of Renault codes.
Tia Alan
Fault codes
Re: Fault codes
0530 code .... A/C Refrigerant Pressure Sensor Circuit Malfunction
0380 code....Glow Plug/Heater Circuit A Malfunction . . . viewtopic.php?t=25896
Looked the codes up here . . . https://www.outilsobdfacile.com/data-tr ... e-obd2.php
Cheers.
Cheers.
Re: Fault codes
Thanks Joe, I replaced the glow plugs about a month ago, so will now check the regulator, also my fan blower has now stopped working, sh1t Renault electrics spoil good cars, I wonder if the more modern ones are as bad!
Users browsing this forum: No registered users and 99 guests
