Engine oil
- Currently Drives:: renault megan dynamique 2006
Engine oil
Hi Im gonna change oil and filter just wondering how much oil do I need to buy, also how do I find out if my megan mk2 1.4 16v 2006 is either 82hp 60kw or 98hp 72kw I've checked on log book but no joy I need to know just for parts on ebay.. Thanks
Re: Engine oil
You will need just under 5 litres of oil.
There should be a sticker with the Hp of the engine in the drivers door opening on the B pillar.
Cheers.
Cheers.
Re: Engine oil
Thank you very much.
Re: Engine oil
Is the oil filter easy to get to also will I need a tool to losen it..
Re: Engine oil
You may be able to unscrew the oil filter off by hand, if it's tight try wrapping a piece of sand paper around it to get a better grip on it.
You will need a 8mm square tool to remove the sump drain plug.
This video below shows the job on a 1.6 but it's more or less the same engine.
https://www.youtube.com/watch?v=D1uWcRZQpJM
Cheers.
Cheers.
Re: Engine oil
Many thanks... Is the engine oil 5w40
Re: Engine oil
The handbook lists a few different grades of oil that can be used, personally I would use the 5w-40.
Cheers.
Cheers.
Re: Engine oil
Hi looked on stickers on drivers side but no mention of hp engine type.
Re: Engine oil
Mine has a sticker beside the door catch.
Try putting your reg in at we buy any car, then it should bring up the car details before you go any further on the site.
Cheers.
Cheers.
Re: Engine oil
Got stickers but no info on hp... Got on one sticker renault megan dynamique 1.4 16 100. Or does the 100 mean 100 hp..
Re: Engine oil
drewster1978 wrote:Got stickers but no info on hp... Got on one sticker renault megan dynamique 1.4 16 100.
I believe the 100 means 100 hp.
I've edited my earlier post with mention of the 6 speed gearbox being on the higher power versions, I forgot your engine is the petrol, I was thinking about the 1.5 dci engined cars.
Cheers.
Re: Engine oil
Many thanks for everyone's help.... Happy new year
Users browsing this forum: Google Adsense [Bot] and 86 guests
