My 1.5 dci 80 has a priming bulb under the bonnet, does this mean it dose not have a lift pump in the tank.
Tia Alan
Fuel pump or not
- Currently Drives:: megane 1.5cdi- mazda mx5-Bond Equipe
Re: Fuel pump or not
The priming bulb is used only when you run out of fuel
Ray
Ray
Or as I found out when you have a leak on a by pass pipe and the fuel runs back to the tank you have to manually prime the system, unlike some that have a lift pump in the tank.
