Megane 2006 hard top convertible, dynamique, priveledge.
they do not work using the switches on the drivers door....and do not work when they top is put open, or when using the centre console window switch.
The passenger side windows work to the switch and also when the top opens/shuts
Fuse issue ? if so, where is the relevant fuse box ?
Thanks for any assistance.
Regards Nick
Electric windows on drivers side not working
Re: Electric windows on drivers side not working
probably the module attached to the offending window,,,you can but a cheap replacement on Ebay BUT automatically closing windows you should currently have will stop working and can only be controlled by the switch..the proper replacements are about £30 all depends on how you finances are
