Hi All,
Hoping you can help me suss this one out as I've not been able to find a more definitive answer...
Megane II 2004, 1.4.
Sometimes, not all the time, I have trouble selecting 1st & 2nd gear, its like Im hitting the stick against a wall.. it wont go in regardless of how hard I press.
It's usually (from what I've found) happening when come to a complete stop, and try to go from neutral - however 3rd, 4th, 5th and reverse all work.
I need to force the gear stick, hold it in and then slowly raise the clutch and... *CLUNK* you will feel the gear 'snap into place'. Then 2nd can be selected with ease.
Not too sure if its a linkage problem, syncro-mesh? or general gearbox issue?
Thanks Ralph
1st/2nd Gear - unable to select without force
- Stranger
- Currently Drives:: BMW X1
Re: 1st/2nd Gear - unable to select without force
Just a guess here but, have you checked engine mounts? Not sure where they are but I seem to remember there's one not too far from the gearbox and with you saying it's an intermittent problem I wonder if it could be due to the angle of the road that you pull up on.
Thanks so much for your reply - no I've not checked them yet. Actually I did a quick youtube search, seems this may be a common problem (engine mounts going).
I did a ebay search and found some for £12... not bad. Is it an easy job? looks like get it on the ramps, and 16mm socket, 3 bolts and its out.
Also now you mention it, the car does also have the following symptoms (mount related?)
* Feeling vibrations through the brake/clutch pedal at the lights
* When accelerating (from any speed) and holding the gear stick, you can 'feel the acceleration' in the gear stick.
Praying for a mount problem, would love if someone had any part numbers I could review?
Thanks again for all your help!
- Stranger
I've never done them so can't say whether easy or not however if you just do a search for 'engine mounts' there's plenty of posts.
Vibration through pedals and movement of gearstick sound typical symptoms though
Good luck with it all
Users browsing this forum: Google [Bot] and 60 guests
