I have a 15 Plate Megane II Limited. Purchased used in March 2018, 28K on the clock.
Recent problem is that after starting off with the radio on everything is OK for about 10/15 Minutes then the radio dies. No station works biut if I awitch to the media (usb Stick) its fine. The way to get the radio on is to stop the car switch off the engine and open the door. Shut the door start the engine and the radio comes back on and this time it stays on. So why does it go off the first time the car is used after being parked. I know that if I sit in the car with the engine off and listen to the radio it does go off after about 10 minutes. Sort of a battery saver routine. Plus this only started happening about 5/6 weeks ago.
Radio Goes off after 10/15 minutes
Users browsing this forum: Google [Bot] and 43 guests
