Headlight not working
As title says, my left hand headlamp is not working I have tried 2 new bulbs, any ideas please?
Re: Headlight not working
broken wire, corroded terminal or fuse
steve-t wrote:broken wire, corroded terminal or fuse
Hi, dont both headlights run off the same fuse?? Also, do you know whether both lights are linked (wired wise), justthinking it could be the link from the working one to the broken one could be damaged??
front left and rear right, front right and rear left, So if 1 fuse goes do not lose all front or rear lights
steve-t wrote:front left and rear right, front right and rear left, So if 1 fuse goes do not lose all front or rear lights
I think I understand what you mean lo
But all my rear lights are working!!
Anymore ideas what could be causing it??
He is saying the fact that your rear lights are working it will not be a fuse problem.
Check your wiring probably a loose connection or broken wire
I have just changed the connections that fit onto the bulb.... Still nothing!!!
HELPPPPP please
HELPPPPP please
Users browsing this forum: No registered users and 92 guests
