I know this has sort of been asked before but I’m going round in circles with no direct answer. So I’m not sure where the issue is.
When I open the roof only the driver side rear window goes down! When all windows are down and you close the roof the passenger window goes up nothing else moves.
The all window by the handbreak switch when you select open again only the driver side rear window goes down and when you select up only that same window goes up.
Lastly all the windows work up and down on all other switches in the car apart from the drivers window jerks up but down is smooth.
I’ve cleaned the centre console switches, the passenger switch and the drivers main switches with contact electric cleaner. To no avail!
Is there a roof ecu if so where is it?
Where do I look and check next please !!!!
2005 Megan convertible roof/window issues
- Currently Drives:: Megan 2 convertible
Users browsing this forum: Bing [Bot] and 80 guests
