Air Blower Faulty
ianearnshaw384
Currently Drives:: Renault megane 07 plate 1.5 dci
Air Blower Faulty
Postby ianearnshaw384 » Sun Jul 29, 2018 6:57 pm
:cry: Hi guys just registered to the club so newbie. I have a 07 Renault Megane 1.5 DCI lovely car always loved it. Anyway i have a faulty blower start with what i have done and checked.
Motor on fan yes works hard wired motor to check.
Blower motor Resistors yes checked and replaced
Replaced the resistor wireing loom as burnt and damaged and the resistor
Relay works fine checked
Checked fuses all fine in front and glove box
So whats the next move to do guys/girls pulling my hair out
joe12
Currently Drives:: Megane estate 1.5dci 86
Re: Air Blower Faulty
Postby joe12 » Mon Jul 30, 2018 2:46 pm
Check the control knob on the dash?
ianearnshaw384
Postby ianearnshaw384 » Mon Jul 30, 2018 3:32 pm
I will try that thank you will come back as soon as i have
Wojta
Currently Drives:: Renault Megane 1.5 dCi 2010
Postby Wojta » Thu Aug 29, 2019 7:51 pm
Hi guys
My fan motor not working. Get new resistor ,
New used control panel speed changes on panel
When remove and touch resistor to negative fan working on max speed so the fan works but I don't know what the problem is and I hope somebody knows please help
Thank you
Renault Megane 2010 1.5 dCi
Wojta
Postby Wojta » Fri Aug 30, 2019 6:05 pm
:pc
I understand that nobody wants to help or like I have no idea what the problem is
activity on the forum is very small I hope it is during the holiday season or it is just the weekend
Jamesb1985
Currently Drives:: Megane cc, Ibiza cupra
Postby Jamesb1985 » Wed Nov 20, 2019 4:35 pm
From what I understand if the blowers work on number 4 only then it’s a problem with the resistor.
Any other issues with it? Fag lighter working? Washers working?
Jamesb1985
Postby Jamesb1985 » Wed Nov 20, 2019 7:15 pm
If you have a volt meter, turn the ignition on and test if you have power to the fan fuse in the glove box. Remove the fuse and just put it to the connector. If there’s no power the feed has burnt to.
Users browsing this forum: Bing [Bot] and 11 guests
