hi everyone
i have a 2007 Meganne convertable 2.0 l which is throwing up check emmisions.
had a test done and fault was lamba sensor codes were reset came back on after a week code showed catalitic convertor. warning lights went off now back on.
as I work in the exhaust industry i get at cost price decided to get cat and sensor changed.
now my question
mechanics rekon there are two lamba sensors on a cat but the cat showing at work has only one so i am not sure what is correct.
any idea?
emissions fault
Re: emissions fault
according to the almost useful Haynes manual, there are 2 sensors.
One in the exhaust manifold and one downstream of the cat.
Good luck
Bob.
Good luck
Bob.
Re: emissions fault
thanks
Re: emissions fault
Update had new cat fitted new post sensor fitted by the garage ibought it off lights just come back on trying to locate pre cat sensor myoldone has a different connector to all the others from motor factors including cross referencing.
anybody else had this trouble
Update
Sorted ordered the part using actual part number off old unit
Update
Users browsing this forum: No registered users and 95 guests
