Hi everyone,
On my 1,5 dci I turned the egr valve through 120 deg and so now is blanked and works fine no lights etc On my Daughters 1.9 130 dci I used a blanking plate on the flexi pipe to the egr but it flashed up check emissions and went into limp so had to remove it. Question is on the 130s does the egr have to be removed by a re map.
Tia Alan
egr valve
Re: egr valve
I've only blanked a C Max once and went ok.
When you did this one did you blank it at the manifold or after the EGR.
Either way, it must have noticed a change in the manifold air pressure l guess.
Don't forget, if it ain't broke, don't fix it.
Bob.
Bob.
Users browsing this forum: No registered users and 96 guests
