rearbrakes
rearbrakes
Hi not sure if this is the right page but I am replacing the rear discs and pads over the next week or so. I know the rear brake cylinders have to be wound back clockwise according to Mr Haynes but do both sides go clockwise I would have thought the nearside went clockwise and the drivers side went anti-clockwise..am I right or got it all wrong....THANKS
Re: rearbrakes
not sure but you'll soon find out. ( Haynes only mentions clockwise )
Trick is to undo the bleed nipple as you turn them in makes it a lot easier.
Bob.
Bob.
Re: rearbrakes
Both go same way. Hope your pad carrier bracket is secured with normal bolts and not torx bolts, all four had to be cut off on mine, could not shift them.
Phil and Liz Jackson
Lanark
Lanark
Re: rearbrakes
Thanks for the information...so all go clockwise and bloody stupid studs are going to be a pig to get off....thanks again...lol
Re: rearbrakes
Hi finally got round to replacing the rear brake discs the bolts were Torx bolts and they came of with no messing.1hr 30 min to replace both sides and that included painting the cross beam with hammerite to cover surface rust....thanks for peoples advice on doing this job....
Users browsing this forum: Google [Bot] and 41 guests
