Automatic Gearbox
Gearjammy
Currently Drives:: MEGANE EXPRESSION 16V
Production year: 2004
Trasmission: AUTOMATIC
Engine size: 1598cc
Automatic Gearbox
Postby Gearjammy » Sun Jun 24, 2018 5:36 pm
Can anyone advise me please what parts I need to change and replace the fluid in the Automatic Gearbox is it a job that I can do myself or is it more complicated does the car need to go into a garage and what parts would I need not much information on YouTube can anyone tell me do I need filters and gaskets or know of any video link I can click to see this being done ?
grandadbobby
Re: Automatic Gearbox
Postby grandadbobby » Mon Jun 25, 2018 1:25 pm
if this is an 02 -08 model, according to the Haynes almost useful manual, it's sealed for life and doesn't need changing.
Is it leaking, playing up etc, why do you want to change it ?
Bob.
Gearjammy
Engine size: 1598cc
Postby Gearjammy » Mon Jun 25, 2018 1:47 pm
Hi Bob thanks for the information it's a 2004 automatic 1.6 16 valve Hatch 5 door ,I really should get hold of this book I might search for one on eBay, The problem is I can hear a winding sort of a noise when the gears are being changed in the automatic mode or in the manual mode then in 4th Gear there's Just a high pitch noise continuously not loud but never the less I can still hear it. A quite a few people ask me why do I keep this old Renault my answer to them compared to some newer cars this Renault is a better and more comfortable drive :D My next thought is how do I check the automatic oil level :?
grandadbobby
Postby grandadbobby » Mon Jun 25, 2018 7:17 pm
remove battery and tray for filler plug.
The level plug is incorporated in the drain plug.
It'll be the inner smaller hexagonal nut, it's a tube that goes vertically into the box.
Have the gearbox warm if you want to do this and warm the fluid going in.
When it starts coming out, let it out till it stops.
Drive the car till hot then loosen and let excess out.
Have to say that from our experience of modern electronically controlled automatics ( ours was the vw dsg nightmare )
if it works well, leave it alone.
Good luck
Bob.
Gearjammy
Engine size: 1598cc
Postby Gearjammy » Mon Jun 25, 2018 8:53 pm
Hi
Bob like you say if it works well, leave it alone. I think that's just what I'm going to do
can't be that much wrong with the gearbox. I get around 38-41 mpg average,
Very much appreciate your help and advice
Regards
Alan
Users browsing this forum: Google [Bot] and 38 guests
