So I've recently had a problem with my car where it starts and drives absolutely fine however the check engine and service light has appeared a few times but then went off again.
I found somewhere that it may be the Camshaft Sensor.
After more google and forum searching I tried to find the physical position of the sensor in my car.
Some places said it is on the left side near my oil filler and other on the right under the air filter.
Ive had a look around with a torch and also looked under each injector bolts and I can't find it anywhere.
My engine is the 1.4l 16v.
If someone could show me with maybe pictures where it is on my car that would be great thanks.
I don't know much about cars but I am quite good at following instructions and fixing things ha!
Thanks James
Where is my Camshaft sensor?
Re: Where is my Camshaft sensor?
no good stabbing in the dark.
You need to read fault codes.
If it were the cam sensor, it probably wouldn't start.
However, it's on you tube for a 1.6
see if yours is the same.
Good luck
Bob.
Good luck
Bob.
Users browsing this forum: Google [Bot] and 70 guests
