Air conditioning not working
- Currently Drives:: MEGANE EXPRESSION 16V
Production year: 2004
Trasmission: AUTOMATIC
Engine size: 1598cc
Air conditioning not working on my Renault Megane 2 I start the engine push the AC nothing clicks in can't hear nothing so obviously its not even getting into the the working mode anyone please got any ideas what it could be is there a way to override the AC switch to confirm it's not electrical problem.
Re: Air conditioning not working
if there's no pressure in the system, it won't work.
It could be just a re-gas but beware it could turn out expensive depending on where and how it's leaking.
My son lives in Australia and uses a/c all the time and no troubles it seems.
It's a system that needs using regular and that doesn't happen over here much.
If you go to a decent re-gas place, they should tell you if it's worth doing or a nightmare.
Good luck
Bob.
Good luck
Bob.
Engine size: 1598cc
I think if I can first pinpoint the problem then I can go from there and possibly maybe get a cheap or less costly way having it repaired but thanks again bob for your information I very much appreciated
Regards Alan
Regards Alan
Engine size: 1598cc
Ok I confirmed that AC clutch does not engage after the AC is pressed and the temperature turned right down and also fans turned up. Before I take the car to a garage does anyone know if the air pressure switch can be overridden to see if it's got a faulty if yes how please.?
you should be able to test the clutch by disconnecting it and connect direct to battery, should hear a click at least.
I think this is on you tube worth watching if you're not sure.
When l test stuff direct like this, l usually use a bulb in line and if it lights up there's a circuit.
Let us know how it goes.
Bob.
Bob.
Engine size: 1598cc
Hi again Bob I will try that have seen some videos on YouTube about the Renault Megane 2 AC not working but not that one you have mentioned. I thought I just checked the fuses and see if there's any blown all seem ok but I have notice a wire disconnected from somewhere it was just at the side of the fuse box under the bonnet. here is a link to my Google Drive of this wire https://drive.google.com/file/d/1KKFK9c ... sp=sharing
when you look at stuff on you tube, remember it doesn't have to be specifically megane, they are all basically the same.
As for that wire, don't know what it is and will look on mine tomorrow, but is it the same colour as what's going to the a/c clutch?
l have a Haynes manual but have found it pretty useless for wiring and sometimes very misleading.
Bob.
Bob.
Engine size: 1598cc
Good advice like you say for the year of my car which is 2004 they all seem to have this clutch device now as for the colour of the Wire strangely enough it does seem to match the colour going to the clutch and the pressure switch sensor hopefully it is something to do with either one
Regards Alan
Regards Alan
Engine size: 1598cc
Took the car to Kwik Fit to check the tracking .I mentioned air conditioning not working to one of the lads he pinpointed it straight away didn't even charge me went back got the part replaced it now working as it should do the part needed was the the air conditioning pressure switch.
kwik fit robber with a heart ? you were lucky
where was the pressure switch ? must have a look at mine, hasnt worked since it ran out of warranty
Phil and Liz Jackson
Lanark
Lanark
Hi scoured my useless haynes book and no mention of this switch, checked most of the pictures and all wiring diagrams (god there funny useless but funny) placement of this switch would be where exactly..THANKS
in search at top of the page, look up ' air conditioning problem'
interesting reading and l think it says the switch behind bumper.
Bob.
Bob.
Cheers for the quick reply...i will check it out later
- Currently Drives:: 2005 Renault Megane II Estate
When I type in "Air conditioning problem" in the search box, it comes back with no hits
if you just google it and mention megane it'll bring you back to it.
Bob.
Bob.
Users browsing this forum: Bing [Bot] and 45 guests
