Hi everyone
Megane II - 2005 1.6 16v Oasis
Today as I was rolling off, as I moved form the biting point the lights dimmed slightly. This has happened before as I am nearly stalled. However, this time, one light is dimmer than the other.
Could this be a potential alternator issue or could it just be a poor/loose connection?
Any advice would be useful!
Potential Alternator Issue?
Re: Potential Alternator Issue?
check all the earths, put a meter on the battery when engine running, should be over 13 volts
Phil and Liz Jackson
Lanark
Lanark
sounds like you need to check the wiring, especially the earth wires at the bulbs.
When l checked mine l found the earth wires were burning out between the side light and headlight, so l soldered new wires on.
It's not a 5 minute job as you need to take the front bumper off the car for good access.
There's plenty on you tube to guide you and it's not too bad, but while the front is off it's a good idea to re-new all the bulbs.
I don't think it's the alternator, but to check it, see if you've got 12-13v at the battery with car running and all lights and heater turned on.
Good luck
Bob.
Good luck
Bob.
Users browsing this forum: Google [Bot] and 75 guests
