Hi. I have a problem with my 1.5 diesel hatchback. The coolant fan is constantly on until the engine is turned off. Plenty of coolant, oil, etc. I've replaced the temperature sensor and it's still on. Any ideas?
Coolant fan running whilst engine is on
Re: Coolant fan running whilst engine is on
it sounds like the relay is stuck on.
I believe it's right at the bottom under the engine fuses and has a number something like 234 on it, but you could maybe pull each relay one at a time to see if the fan stops. You would need jump leads as the battery and tray have to come out and while there check for burnt wires and bad connections, it's not uncommon.
Let us know how you go with it.
Good luck
Bob.
Good luck
Bob.
- Currently Drives:: megane sports tourer
Is your air condition switched on?
Fan will run continuously if Air conditioning
Is on
Is on
Thanks for the replies! Problem doesn't change of the AC is on or off. Took the battery out and the tray out and couldn't see the relays been looking online and in the manual and it shows me that it may be under the upc/engine accessories cover. Problem is I have no idea how to remove it? Any suggestions? Can't find anything online!
Hi just go to YOUTUBE and type HOW TO REMOVE FUSEBOX ON RENAULT MEGANE and there is quite a few to show you exactly how to get to fuses and relays
Users browsing this forum: No registered users and 78 guests
