Airbag faults
Rocker8742
Currently Drives:: 2003 1.9dci Megane II
Airbag faults
Postby Rocker8742 » Wed Mar 21, 2018 11:28 pm
Hi guys,
Got an airbag light on the Megane, read the fault codes today and got the below codes
DF071 - Drivers Frontal Airbag Circuit 2
DF072 - Passenger Second Row Seat Belt Pretensioner Circuit
Now I'm guessing the first is related to the squib and is probably a broken clock spring
As for the second I'm at a bit of a loss? Is it referring to rear seat belt pretensioners, or front seat pretensioners?
Any help appreciated as mot is due :wink:
grandadbobby
Re: Airbag faults
Postby grandadbobby » Thu Mar 22, 2018 1:18 am
l have looked up posts on these codes before.
l found that it's not always the squib.
These codes can relate to the connector block under your seat.
Check that first, if possible check the continuity on each wire either side of the connector to make sure they are connected.
Good luck
Bob.
Users browsing this forum: No registered users and 56 guests
