megane 11 1.5dci injection fault
- Currently Drives:: renault megane ii 1.5 dci 2003 sport tourer2000
Hi,all,I am new to this forum.I was wondering if any one could help me,I have a problem with my 2003 Megane ii 1.5dci sport tourer.I recently renewed 2 x injectors but didn't know they had to be recoded to the engine.I'm looking for an independent garage or a Renault mechanic in the Bellshill area who has access to a clip to sort this out,many thanks in advance Jim
Re: megane 11 1.5dci injection fault
if nobody on here has the diagnostics near you, best google all garages in your area and phone them to find one.
Most people have diagnostic readers but won't be able to code the injectors.
I used to have delphi diagnostics which can do it and it doesn't take long if you've got the codes to hand.
If not, see if you can read the codes off the injectors.
If the injectors have to be removed to read the codes it will obviously take a lot longer.
If the car can't run, you may be better off with a mobile mechanic, l imagine nowadays they would have the necessary diagnostics.
Good luck
Bob.
Good luck
Bob.
Many thanks for the quick reply Bob,I will do some checking
Users browsing this forum: Bing [Bot], Google [Bot] and 86 guests
