Hi Peeps,
I need to take the air vents out - the ones in the center - not the door sides.
I think I have it figures out ... remove the clock surround which exposes two screws ... undo them and the lift out. Is that all there is to it or does the whole dash have to come out?
Everso
Removint the air vents.
Re: Removint the air vents.
according to the Haynes manual, you need to remove the heater control panel surround also.
It says disconnect battery, remove radio, unclip and pull out storage tray below radio, prise out the panel at the front of centre console, remove 4 surround panel mounting screws (2 at the base of panel, 2 inside radio aperture) unclip control panel surround. Disconnect wiring as it's withdrawn.
Hope that helps, at least it's not all the dash.
Bob.
Bob.
Users browsing this forum: No registered users and 78 guests
