Can anyone identify these images as my PCV (Positive Crankcase Ventilation value for my Renault Scenic? (Are Scenics and Meganes the same vehicle?)
When I blow into it, it blows both ways. Also, when I pass water thru it, it goes both ways. As a vacuum value, isn't it supposed to just flow one way?
Do I need to buy a new one?
Thanks! https://i.ebayimg.com/images/g/QqwAAOSwhiZafb8O/s-l1600.jpg
By the way, how do I insert a pic I took with my iphone of the PCV?
PCV for my Renault Scenic 2004 1.9 dci
Re: PCV for my Renault Scenic 2004 1.9 dci
yes that's the breather vent valve and engines are basically the same.
if you can blow through it then it's not blocked.
l don't think it's only one way, it just helps prevent spatters of oil from being blown out.
As an engine wears, there will be a little oil blown by the crankcase pressure to be expected.
If it's excessive, you could try a new part, but it's indicative of engine wear.
When buying a diesel car, l always remove the oil filler cap while it's running to see if it's breathing heavily or if it's good,
You don't want visible smoke coming out of there.
Bob.
Bob.
Thanks for your advice grandadbobby.
