renault megane 1.9 dci coupe 2006
can someone help.... brake lights not working.... middle centre light does but not either side light... bulbs been changed and also fuses all good ... could it be the earth...
Re: renault megane 1.9 dci coupe 2006
do the front side lights work and the dash lights ? Which fuse boxes have you checked ? Did you check the one by the battery
Phil and Liz Jackson
Lanark
Lanark
Sorry mis-read your post its brake lights not side lights
Lanark
Lanark
according to the almost useful Haynes book, the LH rear brake light uses the same earth as the top light, The RH is another earth point, so unlikely to be earths.
You need to test the live wire connections ( orange ) and make sure the bulbs are good and fitted correctly, remember, the pins are off-set.
Bob.
Bob.
Users browsing this forum: No registered users and 55 guests
