Hi, I have a 2008 1.9 DCI Megane. I have recently purchased if from a family who had not been driving it in sometime and it has begun to have issues.
Recently I was having some electronic glitches. It would start first up in the morning with no issue, but then, if I stopped and turned the car off, it would not start, and throw up a "low battery" message. It would be fine after 10Min and 5 re-attempts to start again.
I watched a few youtube videos and have now pulled the fuse boxes out, cleaned or replaced each fuse and put it back in the car. The car ran fine for 2 weeks and then started cutting out while driving. I did have a check injection error in this period but it went away after 2 days. I suspected this error came up as I had put injection cleaner in the tank and after another full tank it cleared it out.
After this I had a full breakdown. The car would start, get about 500m and then the engine would cut. I would have to wait several hours for it to be able to run again. I was getting a glow plug error, and a check injection error. I have now replaced the glow plugs, so every time I try to start the car, it now responds and tries to turn over, but then cuts out. I am still getting the check injection message. I did have a mechanic come and look at it but it didn't throw up any obvious electronic issues on his computer. The messages he did get were not overly specific though the EGR did come up.
Any thoughts on how to get it started? where to look next? cheers, Richard
Check injection
- Currently Drives:: Renault Megane DCI1.9 2008 Sedan
Re: Check injection
anything electrical would give a fault code.
With no code it's usually fuel related.
If I were you I would change the fuel filter and make sure it's bled properly to eliminate that side of things.
Good luck
Bob.
Good luck
Bob.
Users browsing this forum: Bing [Bot] and 73 guests
