Clutch pedal goes to floor
- Currently Drives:: Megan's 2, 2.0 petrol
Hi my clutch pedal goes to floor and stays there unless u pull it up. Although at first it works for a few times before this happens. Is this likely to be master cylinder ?
Re: Clutch pedal goes to floor
first thing is to check the fluid level.
lf that's ok and no obvious leaks, it must either be the master cylinder or most likely the slave cylinder inside the bell housing.
Either way, not an easy job.
Good luck
Bob.
Good luck
Bob.
