Hi all
I have a slight problem when opening/closing the roof. Opening is fine, all works great, but when closing one of the "fans" on the parcel shelf sticks/catches and does not roll into position as the other one does....I have to stop shutting and give it a light push and then it rolls into position and then all shuts fine.
It's very annoying and I can't work out why is sticks. I did give a DW40 spray here and there but that didn't help....when you move it manually it all appears fine....it's as if there is a lack of power to this piece only that prevents is from closing in.
Any thoughts guys ? could it be a spring or something has broken in the mechanism ? I really don't know
Any help gratefully received.
Regards Nick
06 Megane Convertible hard top problem
Users browsing this forum: Google [Bot] and 93 guests
