megane 11 1.5dci
megane 11 1.5dci
Went to access the car this morning but when pressed the key fob nothing happened - tried the spare fob and same result ! Can't access car through the blade because passenger side is parked against a wall! any ideas as to what the problem could be - the car was fine yesterday!
Re: megane 11 1.5dci
it's unlikely that both keys have gone bad if they were ok before
can only imagine somehow the battery has gone dead or completely drained overnight.
Depending on how mechanically minded you are, it would pay to remove the engine undercover and connect a battery charger up to the positive lead coming to the starter motor and earth anywhere on the engine or metal body. If the battery is dead, that should give enough power to open the car.
It may even be possible to pull the bonnet cable enough to open it.
Good luck
Bob.
Good luck
Bob.
Users browsing this forum: Google [Bot] and 67 guests
