Changing card reader
charliehoward
Currently Drives:: Megane 250 RenaultSport Lux & Cup Pack Race Yellow
Postby charliehoward » Tue Jan 09, 2018 2:18 pm
If I change the card reader on my car will I have to do anything to the keycards or will they just work with the new reader?
alanf
Re: Changing card reader
Postby alanf » Fri Jan 12, 2018 4:09 pm
Just buy one from a scrapper, mine cost £12.00 on fleabay, card works ok!
tunamelt
Currently Drives:: 2008 Megane ii 1.5Dci 6spd DPF(fap)
Postby tunamelt » Fri Jan 12, 2018 5:10 pm
i think the only part coded with the key is the Immobiliser. the reader itself only carries the message. should be fine as a direct swap.
konrad
charliehoward
Postby charliehoward » Sun Jan 14, 2018 12:47 pm
I got one off eBay, going to fit it today. My car is supposed to be hands free but doesn't work, could this fix it?
charliehoward
Postby charliehoward » Sun Jan 14, 2018 10:11 pm
I fitted it but it's got the same issue. I assume now it's a key which means I'm looking at £100+ to fix it, is there no solution other than a new key?
alanf
Postby alanf » Mon Jan 15, 2018 1:20 pm
There is a company I used www. option4.co.uk they repair key cards about £20 inc postage try them
charliehoward
Postby charliehoward » Mon Jan 15, 2018 1:23 pm
I just took it apart and resoldered the immobilizer which was very loose so hopefully when I leave work my car will start xD
