Both high beam bulbs not working?
Garrya22
Currently Drives:: Renault megan
Postby Garrya22 » Sun Jan 07, 2018 12:05 pm
Hi folks looking for a bit of help I took my head lamps off to clean the lenses but when I put them both back on it ended up that the high beam is no longer working. I think the fues has gone because the bulbs look fine. My question is where abouts is the high beam fues located?
grandadbobby
Re: Both high beam bulbs not working?
Postby grandadbobby » Sun Jan 07, 2018 6:51 pm
the main beams have separate fuses, F8A AND F8B in the engine fuse box.
If the bulbs test good, ( make sure tested properly ) I would look at the earth connections at the bulb holders.
Unlikely for both fuses to blow unless you did something to blow them.
It's a pain I know, but I think you need the front off again to find the fault, these connections need thorough cleaning and checking, and test all lights before you put the bumper back on, Watch out for the earth on sidelight connects with a headlight and mine were burning out, had to solder new wiring in.
Good luck
Bob.
