Rad fan
Currently Drives:: Renault Megan cc 1.6 black with black leather
Rad fan
Postby alex3025 » Fri Jan 05, 2018 5:59 pm
Hi just wondering if anyone knows if and where the sensor for the cooling fan is ?
1.6vvt 2007 thanks :D
Re: Rad fan
Postby grandadbobby » Fri Jan 05, 2018 9:00 pm
I believe it works off the temp sender in the thermostat housing, via the engine ecu.
The sensor does both the temp guage and fan.
To be sure, follow the wires from the fan, if they don't go to a switch in the radiator like the old days, you'll know.
Re: Rad fan
Postby fredcamp2 » Sun Jan 07, 2018 6:56 pm
What makes you suspect your cooling fan is faulty. To check the system when vehicle is sitting stationary start engine let it sit there idling it will soon reach running temperature then it will soon reach boiling point but just before boiling point your cooling fan has to activate if not then the system is faulty.
Users browsing this forum: Baidu [Spider] and 7 guests
