Hi, new to this and I can see old posts re glow plug changing.
I have a 1.9dci 2005 Megan's estate and want to change the glow plugs.
I can see the top engine cover needs to be removed and once I undid the 2 bolts I couldn't get from underneath the air intake pipe. Does this need moving and if so which end do I undo.
I know I sound a bit thick but ice I can see or know what to do I can sort easy enough I hope.
Glow plug changing.
Re: Glow plug changing.
watch the video on you tube for a grand scenic, same engine.
Bob.
Bob.
- Currently Drives:: 2004 Megane MKII 1.5DCi (80)
I had to remove the injector brace (metal C looking clamp) to allow my socket to get over the glow plug.
With regards to the air intake, I'm assuming you're talking about the large tube going over the engine? If so, just undo the bolt holding it on to the bracket and move it aside.
If not, fancy taking a picture?
Users browsing this forum: Google [Bot] and 109 guests
