I was driving on the motorway and switched gear from 5th to either Reverse or 4th before the engine revs starting decreasing and the car came to a halt.
When I push the start button without touching the clutch or brake the car tries to start but it sounds very crunchy like gears crunching against each other. I already changed the dephaser twice but I do not believe this to be one of the symptoms.
I will try to make a video but can anyone point me what the issue may be?
I have a Megane II 2004 1.6 VVT
Many Thanks
CAR FAILED WHILE DRIVING ON MOTORWAY - HELP!
Re: CAR FAILED WHILE DRIVING ON MOTORWAY - HELP!
Wow sounds brutal!
Will it start with your foot on the clutch and in neutral?
- Currently Drives:: Renault Megane 1.6 VVT Dynamique 2004
The car starts as soon as I press start without pressing the clutch or brake.
It is really strange.
While it makes the noise I pressed the cambelt cover and can hear grinding.
Take the cover off and see if anything is obvious?
I don't think it should start just by pressing the start button, you either have to press the brake or the clutch as a safety feature so that the car won't jerk forward.
Thats right. Your supposed to press the clutch or brake but its starting without any of these pressed now.
Its really strange.
Its really strange.
Not sure that I can help at all but I'll keep asking questions anyway
Does it drive?
Does it drive?
Not if he went into reverse it don't.
My ex-mrs wrecked a driving school car doing that, l wonder if they're insured for that.
Still strange about it starting without clutch or brake though, can only think there's a relay stuck in the engine multiplex module.
Bob.
Bob.
Users browsing this forum: Google Adsense [Bot] and 34 guests
