Tailgate opening when engine running
Trevor9666
Currently Drives:: Renault Megane mark 2 1.5dci estate cars
Postby Trevor9666 » Fri Oct 27, 2017 6:20 pm
Can anyone help please. My tailgate has started opening itself for no reason whilst my engine is running. Another issue that may or maybe not connected is my rear wiper has stopped working at the same time as the tailgate started opening. The wiper will try to move and then unlatches the tailgate.
My Car is a 1.5 DCI Megane estate 2009 mk2
grandadbobby
Re: Tailgate opening when engine running
Postby grandadbobby » Fri Oct 27, 2017 6:50 pm
lf l were you, l'd look at the tailgate switch and rear wiper motor and all connections for damp or water ingress, it only needs to be damp to cause problems.
Bob.
Trevor9666
Postby Trevor9666 » Sat Oct 28, 2017 12:49 pm
Have sorted problem with my tailgate opening problem. After investigation I discovered 4 wires had been cut inside the rubber flexi trunking from the cabin to the tailgate. have fixed these and hopefully have cured the problem.
grandadbobby
Postby grandadbobby » Sat Oct 28, 2017 5:45 pm
on my car, the rear wiper does a quick wipe everytime l start the car.
lt's a fault in the interior multiplex module which l can live with.
When l leave somewhere, it's like the car is waving goodbye.
You may find something like this with your car, hence the wires cut.
Good luck and well done finding it.
Bob.
Users browsing this forum: No registered users and 95 guests
