Megane 225. Acceleration problem
Chappyboro
Currently Drives:: Megane sport 225
Postby Chappyboro » Fri Aug 25, 2017 8:36 pm
Wondering if some one can help.....
I have a 06 megane 225
When accelerating hard @3K the car seems sluggish and no boost or no power
I've changed the plug witch are ngk.
And changed all coil packs
grandadbobby
Re: Megane 225. Acceleration problem
Postby grandadbobby » Sat Aug 26, 2017 5:50 pm
not conversant with that car, but the chances are you need a fault code to work on.
Otherwise, is the fuel filter clear and the tank can breathe.
Bob.
Chappyboro
Postby Chappyboro » Wed Aug 30, 2017 1:11 pm
Hi
I have limit knowledge about fixing car but not totally clueless how could I check the fuel
Thanks mark
grandadbobby
Postby grandadbobby » Wed Aug 30, 2017 8:18 pm
Hi Mark,
take a look on 'megane sport' forum, it looks like the filter is part of the pump.
You may need to get the pump tested also.
Good luck
Bob.
Chappyboro
Postby Chappyboro » Wed Aug 30, 2017 9:22 pm
Hi Bob
If the pump is not at fault what could also be a suspect
Injector?
grandadbobby
Postby grandadbobby » Thu Aug 31, 2017 12:04 am
lf it was an injector or anything electrical you will get a fault code.
You need a diagnostic tool if you want to work on it yourself.
lf there are no fault codes then fuel would be the suspect.
Bob.
Chappyboro
Postby Chappyboro » Thu Aug 31, 2017 6:19 pm
Hi Bob there isn't no fault codes so fuel it may be
Postby AlexB » Mon Sep 11, 2017 2:53 pm
With a fuelling problem there will be abnormal trim values on OBD...
You may also look at the boost pressure live readings, also on OBD.
One more option is the dephaser stuck in the retarded position. If the case, then it may rattle on startup or may be just stuck.
Chappyboro wrote:Hi Bob there isn't no fault codes so fuel it may be
Chappyboro
Postby Chappyboro » Sun Oct 29, 2017 7:47 am
:cool: . Finally got it sorted turn out to be fuel pump £80 later and all do
It was failing under load
Thanks for your help
Users browsing this forum: Google Adsense [Bot] and 54 guests
