My car won't start
My car won't start
Hi I have a 2008 Renault magane dynamic that won't start when I press the the start button a message comes up on the dash saying turn steering wheel press clutch or brake and push the start button and still won't start can any one help me out or it's going to the scrap yard
- Currently Drives:: renault megane 2005 1.5dci automatic
Re: My car won't start
Hello there.....usually the starter motor gets a pulse on the activation lead ( this lead activates/operates the starter solenoid) and then the starter motor turns. Can you check to see if your starter motor is turning. On manual transmissions one has to press the clutch pedal before pressing the starter button. Looking at the Haynes Manual it shows a clutch pedal switch consisting of two wires. If you could check the continuity of this switch with a multimeter and when pressing the clutch pedal you should see continuity on the ohms scale. The start/stop button also has a micro switch and it should be possible to check its continuity with a multimeter as well. With an automatic trans, its the brake pedal that has to be pressed before pressing the starter button. rgds Maurice
on you tube it shows a scenic where the bloke slides a knife in with the card and it starts.
Have a look, it might help till you can sort it properly.
Bob.
Bob.
Users browsing this forum: Google [Bot] and 40 guests
