aircon low pressure port
Hi I have a 2001 Renault megane 1.6 16v and wondered if anyone can tell me which is the low pressure port for the aircon?
Re: aircon low pressure port
look up 'how to recharge air conditioning system' on megane 2 owners site.
Google it if it doesn't come straight up on here.
Bob.
Bob.
- Currently Drives:: renault megane 2005 1.5dci automatic
Normally there are two air con pipes attached to the air con compressor pump. One is bigger than the other. The bigger pipe is normally the low pressure pipe. Follow the bigger pipe back from the pump and you should be able to locate the low pressure nozzle ( port) on this pipe.
rgds Maurice
rgds Maurice
Users browsing this forum: Google [Bot] and 42 guests
