air con fuse and relay location megane mk3
hi guys,can any one here please tel me where the location off the fuse and relay is for my megane dynamique tomtom i.6 is ive tried online and got know where lol thanks in advance ps pictures would be good , mark
Re: air con fuse and relay location megane mk3
Hi on my 2006 model the fuse is in the Engine Bay fuse box which is under the battery next to or connected to the Engine Multiplex Module if there is a relay that should be there also...sorry cannot help more
thanks need to know which fuse and relay its doing my head in lol
thanks scooper when i make sense of the diagram ile let you know lol
I have got a similar problem with my car there is no power going down the orange wire to the compressor, the fuses in my car are in the black box to the right of the battery, you do need to remove the battery and tray to access the fuses and engine multiplex unit, I plan to make sure power is traveling from heater control unit Blue Wire to the multiplex unit then check fuses if these seem to be OK I might set up a relay from main fuse box to the orange wire powered by the Blue Wire so when the climate control is triggered the compressor kicks in....this week I had the system regassed and did rig up a power supply and compressor works great.....good luck with yours
hi scooper is yrs a mk3
No sorry a MK2 2006 model....there was only a minor change in the fuse box location from the MK1 to the MK2. So hopefully the MK3 is similar
