Clutch pedal problem
Hi newbie here I have just bought a 06 megane estate and the clutch pedal was fine for the week and now it as started acting up I can only describe it as like a automatic clutch adjuster was missing some teeth, depressing the pedal or even releasing the pedal it clicks loudly and if I am pressing it down jumps a inch or so, I am getting used to it my old Citroen Xantia had a automatic adjusted cable clutch and that did the same thing BUT the megane is hydraulic so I presume it's not got a adjuster involved with it...any ideas would be appreciated..Thanks in advance
Re: Clutch pedal problem
Hi now sorted.... ![big smile :D](./images/smilies/Joker_PDT_06.gif)
Hi there,
glad you sorted it. lt could help someone else if you explain the resolution.
Bob.
Bob.
the short linkage from the pedal to clutch cylinder on the leftside of pedal was not connecting properly , it kept slipping off not fully but enough to make the clutch pedal jerk, i solved this by using a length of elastic and tieing the pedal and shaft together at the joining point so the connection is now more secure, i used elastic to get a bit of "give" in the join
Well done on using your initiative, let's hope it holds.
At least, next time if it happens, you know what the go is.
Bob.
Bob.
Cheers Bob...easy fix once I got my big head down to see what the problem was..lol
Users browsing this forum: Google [Bot] and 87 guests
