So went to my 07 Megane II this am and it won't fire up. The lights come on, and it tries to turn over but instead of starting, there is a quick clicking noise in quick succession.
My instincts are either damp somewhere (as the car is now showing its age) or the starter motor in need of a swift knock with a lump hammer (and then changing if the DIY solution does not work).
Having look for the start motor i'm stuck, managed ot get a workshop manual but it was in Spanish - and my Espanol extends to 'Dos Cervevas por favor'.
Anyone got a link to where the start motor is / manual that is usable?
Thanks in advance.
T
Starter Motor?
Re: Starter Motor?
On the 1.9 dci it is round the back under the turbo down pipe. Are you sure its not just the battery that has failed to hold charge and not enough cranking power to turn the starter motor?
Re: Starter Motor?
Thanks for the info CraigyT.
This is the 1.6 Petrol, not sure if it makes a diff? I'm going to go over the battery and swap it out tonight, hopefully this resolves it. If not i'll bee hitting the start motor with the lump hammer....once i find the bloody thing
T
T
Users browsing this forum: No registered users and 67 guests
