Hand Brake manual use,
- Currently Drives:: Renault Megane 1.4 RT 5 door 1999
Renault Megane, 1999, 1.4 RT V6 Hand brake is jammed on full hold, cannot move button at all, any help appreciated,
Re: Hand Brake manual use,
if you can't move it at all, you will need to undo where it is fixed in the console or to the floor.
Good luck
Bob.
Good luck
Bob.
Thanks Granddaddy , At whits end, with jammed hand brake, ran engine, pumped brakes ---- got so fed up -- I stamped on the brake pedal
--- that did it ! Hand break released ! suggestion --- loose your temper !
Users browsing this forum: No registered users and 56 guests
