Boot wont open (Resolved)
- Currently Drives:: Renault Megane 1.5DCI Dynamique 2004
Hi all, megane 2004 i have a problem with the boot not opening, used to work then stopped all of a sudden. Press the buttom and nothing happens not even a sound please help or point me in the right direction to fault finding thank you
- Currently Drives:: megane privilege
Re: Boot wont open
I have this issue on a regular basis. Water gets in the switch unit. Mine eventually fell apart so was stuck with a car that wouldn't lock and as the sensor detects the boot is open it wouldn't start either! It's fiddly, but I had to take the switch out and re build it. It's been fine since, but you have to work out how all the copper conductors go in for it to operate properly which can be a challenge! Good luck
Re: Boot wont open
Thanks for the reply, do you mean the black button that has to be pressed to open the boot???
Re: Boot wont open
The black tailgate open button can be one element, or some wire could snap in the wiring loom that supply tailgate, it is inside rubber snake at the junction of the car body/tailgate. If you will find broken wire / wires I had 7), they will need to be joined. Last time mechanic took £30 to do it as I was in a rush, but they broke again so now I put new wires with connections away from the snake so there are no tepair connections where the wires are bending so this repair should last longer.
- Currently Drives:: Megane 1.9 dci 06
Re: Boot wont open
Mine doses this so got a new black button from eBay sorted now
Re: Boot wont open
It was the catch on the boot all fixed now
- Currently Drives:: Renault Megane 1.9 dCi Dynamique Estate
Re: Boot wont open (Resolved)
When the tailgate on my Megane wouldn't open, I discovered that it was broken wires in the flexible hose near the hinges joining the tailgate to the body of the car. I soldered-in new wires to join the ends together with the solder joints in the tailgate and the car body to protect them from the movement of the tailgate opening and closing.
